Coolant at Minimum?
Coolant at Minimum?
Every couple of weeks i find my coolant level at the minimum so i top it off to max with some water. I know i should use antifreeze but what i thought what happened is that water just evaporated and the mix was just a little more concentrated with the antifreeze? Like if you boil down salt water, the salt stays but water evaportates. So i added water to make up the difference, but every 4-5 weeks its back at minimum. Is this normal? I am sure there are no leaks.
