Coolant leak
Coolant leak
Hello, I have a coolant leak at the water outlet from the engine block. Is there anyway to access this without having to remove the intake manifold? Maybe it is accesable from below. I am guessing the little rubber o ring has gone south and needs replacing. Anyone else have this problem? or ever replace this part? Thanks.
its tricky but you can get to it if you take off the tensioner and alternator and the bracket that supports the IN. manifold. and the worst part is that your arms will be bleeding after you finish the job
Prolene
04-17-2002 11:10 AM
