Coolant Issue but i have heat..
Old 10-22-2009, 01:20 PM
SpoolinU's Avatar
thanks alot dude i appreciate it, ill take a look later n see what i come up with..
Old 10-22-2009, 01:51 PM
SpoolinU's Avatar
no HG issue.. absolutly no milky color to my oil nor does it make bubbles when the car is revved up with the radiator cap off..and the plugs r burning fine they r not clean
Old 10-22-2009, 06:40 PM
Tech7427's Avatar
what is the ambient temp of the outside air> have you drove the car off idle?
whats the temp bars on the cluster look like?
Old 10-22-2009, 07:43 PM
SpoolinU's Avatar
temp outside was probley like 65-70 degrees. i haven't driven the car i was afraid to mess anything up more then it might already be.. itll go as high as 4 bars then drop back down to 3
Old 10-22-2009, 07:55 PM
Tech7427's Avatar
you more than likely just have air in the system. pop the cap off, jack the front end of the car way into the air, and start reving it up around 2000 for awhile and then let it sit, put the cap on. rev it some more.. turn the car off, crack the bleeeder on the intake manifold til cooalnt comes out pure no air.
Old 10-22-2009, 08:03 PM
SpoolinU's Avatar
Will the coolant still come out since the radiator cap will be the highest point when it's jacked up?
Old 10-23-2009, 09:33 AM
fuel4blood's Avatar
No problem
Ek_Jak
11-29-2015 11:14 AM
Omar46
02-26-2015 08:27 AM
Allday
01-08-2014 03:23 PM
zbrewha863
Jacksonville
12-02-2010 01:53 PM
GA2000S2000
05-13-2007 09:11 PM
Quick Reply: Coolant Issue but i have heat..
