Coolant?
Coolant?
i was doing my usual weekly check-ups yesterday and noticed the coolant a little low. what type of coolant does honda use and is it anything like toyota where they have a special formula? meaning can i drop prestone or do i have to buy a honda coolant.
Adding factory Honda coolant is always the safest bet.
I see you live in SD, you can even just add distilled water to make your boiling temp higher since you most likely don't need the anti-freeze properties.
