Convertible Top Gap
Originally Posted by HondaS,Jul 1 2007, 04:56 PM
yours are probably pretty worn out you just dont know it yet
i put some on like 2 weeks ago and my car is quieter than my previous honda civic i was stunned when i took it on the free way
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
are hardtop strikers a fix simply because they are new and not worn, or are they actually lower/shorter than the usual strikers and so pull the top tighter? anyway, they're less than $50 thru hardtop guy. the washer idea occured to me before it was suggested, so i think i may try that, and if that is a no go then i'll buy some new strikers. thanks everyone.
there is a tsb for our '01's that say if you have excess wind noise, try hard top strikers because (iirc) they hold the top better than regular strikers.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
Make sure that when the top closes the little "bump" on the front of the latch is going into the "dimpled" area on the portruding end of the striker. When I close my top the little "bumps" always rest on top of the strikers....i can still latch the top but there is a gap so I have to make sure to pull the top down and back a bit to get the "bump" into the "dimple" then i have an air/water tight seal!
hope this helps...i triend the hardtop striker replacement and found the above was my problem all along.
Mr Bill
07-22-2014 10:31 AM
