Continuous Fan operation
Hi all,
Picked up my S2000 last week and have noticed that what I presume is the radiator fan is constantly running, even from cold starts. I assume this isn't normal behaviour for the S2000?
Any thoughts to what it could be? The car still seems to warm up quite quickly, and I have checked that the A/C is switched off so it's not the A/C fan in operation. Thinking it can't be doing the car any good on cold starts really.
Thanks
Thanks
Just remebered that the car is going in for a new alarm tomorrow at an auto-electricians. I'll get them to test the thermoswitch while it's in. Does anyone have the part number to hand in the event that it's found to have failed?
Thanks
Thanks
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
37760-P00-004
try this number
it's about 40USD, you can check the voltage of the wire, i didn't bother after i found mine was busted, just replaced it.
have the tech check for any slice wire, there might be a switch or a ground that trigger the fan on, most likely a cheap modification for racer.
I ground out the thermo on my mazda so the aux fan will run all the time because the cooling system is undersized.
try this number
Thanks for that, hopefully be able to swap it out on Saturday.
However, I have discovered possibly an unrelated problem or the the cause.
1. On ignition, the radiator fan (nearside) turns on regardless of temp and runs until ignition off.
2. Similarly, the A/C fan (offside) also turns on regardless if the A/C is in operation or not.
Initially I thought it was something simple like a bad thermoswitch for the radiator fan, but the A/C is confusing, unless it works in conjunction with the radiator fan when needed. As far as I can tell the A/C is not stuck on, as I can hear a relay engage when I press the A/C button. (Although no real rise in revs when doing so)
It's as if the A/C is stuck on somehow. (This is with all heating controls set to off) Would the A/C wind up both fans? Perhaps pulling the relay might shed some light?
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
You'd be amazed at little things people do to cars.
I have never hear of both fans running while cold on an s2k, unless someone hard wired them.
Cant hurt to ask.
Cant hurt to ask.
rikhemi
06-12-2017 11:11 PM
Chance S2K
05-07-2014 09:41 AM
