condenser question
condenser question
Can anyone tell me if the line coming out of the condenser going into the receiver drier be cold,warm,hot when the AC is running ?
Here's a picture of the line
Uploaded with ImageShack.us
I don't have my S2000 yet, but I deal with refrigerant for a living. Leaving the condenser, the smaller high pressure line (liquid) should be warm to the touch. The larger low pressure line leaving the evaporator (coil in the dash) should be cold going to the compressor, from the compressor the line should be hot... Then going to the condenser. Pretty sure the tank is just a drier (filter) tied into the liquid line. It should be warm/ambient going in and leaving. If its cold leaving the drier then the drier would have to be replaced.
Thanks
If he put gauges on it then he should be able to tell what the problem is. If there would be a "blockage" in the condenser, the high pressure switch would open. I'm trying to find a wiring diagram but I'm not having any luck. However a blockage in the condenser sounds like BS to me.. Can't say I've ever seen that before. That's what the drier is for. Sounds like its low on refrigerant. Did he tell you any of the pressures?
If th condenser is blocked, then you got junk everywhere in your ac system. Sounds like whoever worked on your ac in the past never evacuated it (ran a vacuum pump on it to get rid of all the moisture). Moisture along with hot refrigerant will create sludge. Sounds like the guys looking at it don't know what they are doing. They're running out of pars to change.. A plugged condenser just seems like BS. If you're able to find out what the low/high side pressures are I can give you a good idea what's wrong.
A condenser isn't that different from a radiator. Biggest reason a condenser is bad.. It's leaking refrigerant (which is rare) Second reason would be the it's not rejecting enough heat.. So the liquid line leaving the condenser would be hot. If its not rejecting enough heat, wash it. I would really take your car to a different mechanic. Sounds like the guys working on it are clueless. I'm assuming there's a wiring diagram for the car somewhere. I don't see why they can't determine which pressure switch is opening.. If its low on refrigerant, the low pressure switch will open. High pressure switch if there's a condenser/condenser fan issue
