condenser fan fuse keeps blowing
Im trying to iron out all the kinks on my recently purchased s2k. The ac does not work, I checked the fuse box and the condenser fan fuse was blown. I turned off the car and replaced it and it immediately blew again. Any known problems or do I have to go the old fashioned way and follow the short? Thanks
Maybe the motor is froze up or shorted out. I'd try pulling the condenser fan and applying power to the leads and see if it works. If not, that's more than likely your problem.
I pulled the connector to the fan and then put another fuse in and it blew immediately. So I'm thinking maybe a bad relay or a bad ground somewhere.
