Comptech Supercharger Dyno Tuning Results
Old 01-13-2003, 09:32 AM
  #41
jlangton's Avatar
ASP said they could make it in alum or steel......What would you guys recommend is the better material and why?
Thanks again guys
James
Old 01-14-2003, 03:22 PM
  #42
jlangton's Avatar
Thanks again guys
James
^^^top^^^
Old 01-14-2003, 05:23 PM
  #43
Yellow Streak's Avatar
Thanks again guys
James
The one I had made is made of aluminum. I believe that the stock Comptech pulleys are made of aluminum as well. Since they appear to be strong enough and are likely lighter than steel, I would stick with aluminum.
-YS
Old 01-14-2003, 05:36 PM
  #44
jlangton's Avatar
Cool, thanks alot, you've been a big help......
join the darkside yellow one
Old 01-15-2003, 02:46 AM
  #45
1Randyc's Avatar
Here is what I know based on some experience and opinions from the pulley expert.
Steel material pulley is extremly heavier than the aluminum one, I would say almost 5times heavier, yes that heavy!
If you are going for moderately smaller size pulley as Yellowstreak have done, definitely stick with aluminum.
If you are doing quarter size pulley like I have , it may be better to stick with steel material. Steel is better for gripping and heat dissipation and as the pulley gets exteremely smaller, heat build-up and grip would be majorly challenged.
Old 01-15-2003, 05:24 PM
  #46
jlangton's Avatar
Cool, thanks for the info.......I will have an aluminum one made now, only about 4"....eventually when I decide to really raise the boost, I will go with the steel.
Old 01-16-2003, 02:56 PM
  #47
VTECPHIL#6829's Avatar
I AM NEW FORMULA RED WITH ENVY! YOUR CAR IS ABSOLUTELY GORGEOUS! pHIL
Old 01-17-2003, 02:24 AM
  #48
Thanks Phil
-YS
Old 01-17-2003, 10:50 PM
  #49
Nobody's Avatar
Does the blow off valve screw up drivability?
Old 01-18-2003, 05:32 AM
  #50
I have not found there to be any difference in driveability. I believe the Vortech and Speedcraft kits both blow off to atmosphere as well. The original BPV was most likely used to get the CARB certification.
-YS
ScoobyLai
02-28-2010 10:24 AM
S2000_Europe
02-02-2004 06:49 AM
Wesmaster
05-27-2001 08:41 AM
RT
01-28-2001 11:55 PM
Quick Reply: Comptech Supercharger Dyno Tuning Results
