comptech s/c install Q
I have the comptech s/c kit installed w/ the ESM and in the process of installing the Emanage - do I disconnect the ESM or run it along with the Emanage?
Also, I was leaking oil around the oil feed line to the blower. Actually the screw that goes into the blower. Should I be using teflon tape?
Thanks!
Ray
Thanks!
Ray
Ray
Regarding the ESM:
If you are going to use the Emange you can take off the ESM, because the Emanage has an option which subtitude the ESM, Boost sensor,
You must to input 2.7 in the whole RPM range
You should not need to use teflon tape
Regarding the ESM:
