Comptech Install
#31
I guess I should jump on this thread as well....as I have a few questions myself.
I recently purchased a used Comptech CAI on the For Sale thread. The intake is in good condition, but I didn't recieve all the parts that come in the retail box. After reading the installation instuctions found on Comptech's web site, I think I know what I will need.
Will I be able to buy most of this at the local autoparts store or will I need to special order from Comptech?
I'm assuming I'll probably have to order the Filter Oil.
Also, can anyone tell me what size/type the 3 stainless steel screws are?
I'm sure there will be more questions to come.
Thanks for any information
- Valve Cover Vent Hose
- 5", 26" & 22" Vacuum Lines
- Coolant Bypass Line
- 5mm & 6mm Hex Bolts
- Air Solenoid Spacer
- Stainless Steel Screws
- Filter Oil
#32
[QUOTE]Originally posted by danguyener
another question,
if i got the CT S/C kit and my car bone stock would this be safe for car or would i have to get some other mods first.
(i want the sleeper look,heh)
another question,
#33
[QUOTE]Originally posted by Cheetah
I recently purchased a used Comptech CAI on the For Sale thread. The intake is in good condition, but I didn't recieve all the parts that come in the retail box. After reading the installation instuctions found on Comptech's web site, I think I know what I will need.[LIST]
[*] Valve Cover Vent Hose
[*] 5", 26" & 22"
[*] 5", 26" & 22"
#34
[*]Air Solenoid Spacer
Are you referring to the sir solenoid on the vacuum tank down by the steering rack? I couldn't tell how it was supposed to be installed so I used a cable tie and it holds nicely. Is there supposed to be some part down there? A bracket or spacer stube and bolt? That would make sense.
I'll see if I can get a photo of my cable tie mount. Everything else in your list is just normal auto supplies.
#35
I'm not sure what the 'Air Solenoid Spacer' is. I just got it off the installation checklist for the intake located here:S2000 Comptech Intake Installation Instructions
I just stopped by the closest auto parts store and the salesmen mentioned that I will need to know the size of the following:
# Valve Cover Vent Hose
# 5", 26" & 22" Vacuum Lines (I'm assuming he needs the diameter)
# Coolant Bypass Line
Ugg....I guess it's best for newbie modders to buy new so they get all the pieces up front
#40
Which filter do you think is better, the comptech or the spoon filter? Also, do these filters make that much of a difference over the stock filter? Do the comptech and spoon just slide on easily? Thanks
