Comptech Install
#22
I think it is too long also the plastic around the stock filter is not malleable enough to use a clamp to tighten around the Comptech tubing. Might slip off IMO.
No no just one more thing, Comptech exhaust and then it will be my dream harley!
Originally posted by darkknight1999
Yeah you learned a lot....you learned you need more asap
#24
Foam oil generally is more viscous than gauze oil - use what they recommend because oil on sensors is a real PITA.
Work the stuff through with your hands, and then I like to blot with a few paper towels to ensure there is not to much oil on the filet - too little is better than too much, since the force of the airstream and capillary action will tend to disperse the oil evenly in a short while.
#26
Well, I did a search and Sirusrex used the K&N without any problem, so I ended up using that. I could always order the Uni brand, clean and re-oil with that.
Road Rage, you are the go-to-man for all things oil. Nice to have you on the boards! You just aswered my follow up question, which was "Can you over oil the filter". I think I did, so I blotted some off.
Thanks!
Thanks!
#27
this might be a stupid question but here goes(im also new)
if i got the CT cai would it fit with the CT S/C?
it looks as if it does but just wanted to see.
Thanks
Thanks
#28
CT = comptech i assume
yes it will but you'll have an extra CAI. The CAI that you can buy seperately is the same as the one on the kit, this is why i still didnt buy the comptech CAI cause i'l saving up for the SC
#30
another question,
if i got the CT S/C kit and my car bone stock would this be safe for car or would i have to get some other mods first.
(i want the sleeper look,heh)
thanks
thanks
