Comptech Air Water Aftercooler campatible Blow off Valve or Pop off valve?
Old 10-16-2003, 10:55 PM
  #21
RT
RT's Avatar
Originally posted by Honda-S2000VTec
Does that mean there isn't something better that can be installed in its place?
www.stratmosphere.com
Old 10-17-2003, 12:19 AM
  #22
M-Type's Avatar
well that will work if the one comptech gave you is leaking, but i think the original question was about a blow off not a bypass. I think the original question was asked to see if we can get that "shooosh" sound out of the comptech charger by bolting on the blowoff valve on the cooler.
Old 10-17-2003, 03:43 AM
  #23
Sub-Zero's Avatar
You bet you can shoosh it. You just won't get as much shoosh as the Turbos running more than twice the psi. But you can still get a BOV that will work. If you set it to relief at the same psi or just a little greater, and remove the comptech one, the S/C should work as advertised.
I'm looking for a BOV now to bolt on my Aftercooler that was mailed Weds. Can't wait!!!!!!!!!!!!!!!!!
Old 10-17-2003, 04:03 AM
  #24
S2000_Europe's Avatar
Carlton..
I have been runnig UR turbo below vtec (5psi) and you can heard the pssssssssssssh, Comptech runs 6.5 psi at 8000 rpm so you should be able to heard it
Old 10-17-2003, 02:50 PM
  #25
M-Type's Avatar
yea i've heard greddy boltons on Integs running 6-7psi. True that it will not sound at low rpm but once you take it to vtec wow
Old 10-17-2003, 02:52 PM
  #26
M-Type's Avatar
and clarton keep me updated on which bov you found/get!! i will likely get a bov once i get me a comptech charger
Old 10-17-2003, 04:00 PM
  #27
Sub-Zero's Avatar
The Supercharger belt slows the charger down so there is not as much sound as a Turbo that winds down with the exhaust. I can hear anything with the relief valve that is on it now and I know it has to be relieving some pressure. I think if anyone want a loud sound the trumpet type BOV would be perfect.
Old 10-17-2003, 04:13 PM
  #28
Nobody's Avatar
I'm a bit confused--why do people bolt BOVs on to the Aftercooler when the Bypass valve can be replaced with a BOV? What am I missing?
Old 10-17-2003, 07:53 PM
  #29
M-Type's Avatar
its the same (i think). Its just that the aftercooler provides a solid support, where the bypass is sorta freehanging on the intake box (less stable). also the aftercooler have 4bolts holes that people could use to bolt the bov on.
my 2 cents
Old 10-17-2003, 08:49 PM
  #30
Honda-S2000VTec's Avatar
My reason for wanting to change the current set up is to keep heated pressurized air from re-entering the intake and creating even more heat the second time through the S/C.
Quick Reply: Comptech Air Water Aftercooler campatible Blow off Valve or Pop off valve?
