Comptech Air Water Aftercooler campatible Blow off Valve or Pop off valve?
Old 10-02-2003, 09:36 PM
Honda-S2000VTec's Avatar
Default Comptech Air Water Aftercooler campatible Blow off Valve or Pop off valve?
I have heard about someone recommending a Vortech blow off valve and using it on a new Comptech air water aftercooler. I went to the Vortech website and didn't find anything that would match up to the 4 bolt hole pattern. Does anyone know what Blow off valve or Pop off valve mounts to the new Comptech a/w aftercooler?
Old 10-12-2003, 04:17 PM
1Fast99Si's Avatar
TTT
Old 10-14-2003, 02:55 PM
Sub-Zero's Avatar
Call comptech I don't have the spelling right but it is somthing like Sade.
Is there a manufacturer like that. That is what it sounded like when I called them.
Old 10-14-2003, 04:02 PM
M-Type's Avatar
you called comptech and thats what they told you? Would it void the comptech warrenty? I know it might void the carb certification
Old 10-14-2003, 04:25 PM
Nobody's Avatar
It may void CARB certification, but I can't imagine some bloke at a Smog certification place knowing that.....
As far as I know, though, the only way to get a BOV on the Aftercooler is to weld one on. There is a Bosch Bypass valve and it looks like that could be replaced with any aftermarket BOV that fits on an Audi or VW 1.8....but so far nobody has been able to confirm that.
Old 10-14-2003, 11:37 PM
M-Type's Avatar
I"ve heard that some one on s2ki have a BOV on their Comptech charger (without cooler). I've tried searching for threads on it but i cant find any. Does any one know the guy/girl, i think the name was lile "red streak" or somthing.
Old 10-15-2003, 01:19 PM
rocketman's Avatar
I thought superchargers didn't need blow-off valves
Old 10-15-2003, 02:16 PM
Asura's Avatar
Tech2Drew has a blow off valve on his comptech with AC. I think it is made by Venom (guessing). PM him, he is a board sponsor.
Old 10-15-2003, 05:14 PM
M-Type's Avatar
Well any kind of force induction before the throttle will build pressure and you need a way to release the pressure.
Old 10-15-2003, 05:15 PM
M-Type's Avatar
Well any kind of force induction before the throttle will build pressure when the throttle is closed and you need a way to release the pressure.
Quick Reply: Comptech Air Water Aftercooler campatible Blow off Valve or Pop off valve?
