Comptech Aftercooler leaking coolant out of refill cap.
It was the first time the temp. hit 80 degrees since I had the cooler and I did about an hour of driving. When I stopped I smelled coolant. Popped the hood and I see bubbles coming out of the after cooler right around the refill cap. It not shooting out or anything and there was just a couple drops on the ground when I pulled away. Happen to anyone else?
Check the little gasket on the underside of the cap. It may be damaged, misaligned, slightly warped or missing altogether. I'd get a new gasket. I fill my Vortech cooler right to the bottom of the filler neck. No leaks.
Originally posted by buzilanga
Anyone tried filling it with liquid nitrogen? If you keep it in liquid form, it wont evaporate right?
I see only you have a background of l N2.
