Compression test results.
First off a little background. 2001 68,800 miles. Perfect and strong idle. Drives like a champ. A little worried though about my numbers. How worried should I be?
1-190psi
2-190psi
3-180psi
4-175psi
When we added a little oil to each the numbers jumped to 205-230psi.
Shouldn't my car be acting up if something is seriously wrong?
Any input is appreciated.
1-190psi
2-190psi
3-180psi
4-175psi
The only time I seem to burn up the oil is when I'm heavy on the vtec. Other than that I do not have any out of the ordinary oil consumption.
I want to make sure that you understand we added a little oil to each cylinder. That is what bugs me when the numbers jumped.
Originally Posted by Z06-KILLR,Oct 8 2006, 09:27 AM
While your numbers are slightly low, they are well within the norm. They all seem to be pretty similar also. I would not worry much about it.
Last night we took the VAFC out and are seeing how the car runs stock to make sure it was the wiring. I was getting an occasional random missfire. The dealer told me it was the VAFC but that he was going to mess with the wires.
Well now that its out I will see what happens.
Thanks for the replys.
Originally Posted by Kenpo_S2000,Oct 8 2006, 01:39 PM
If its coming from you that they are normal it makes feel a lot better. You know your stuff. I didn't see how it could be anything major because everyone talks about horrible idles and running crappy. This idle stays in one spot and never moves. The only problem I was getting was from a crappy wiring job the previous owner did on my VAFC II.
The largest variation between yours seem to be at 8% but all of them seem to be on the low side. If you are gaining compression when you add oil then you could leak somewhere...
Have you run a leak down test?
Originally Posted by iamhomin,Oct 8 2006, 10:27 AM
So any number below 180 (I'm assuming) is bad?
Nominal: 228psi
Minimum: 135psi
Maximum Variation: 28psi
If you had all of them around 170-180...I guess by "Honda" standards, you would still be ok...
