Compression Test results in.
So I finally compression tested my car. Should have been done ages ago but there it is.
Results were 160, 155, 153, 160
All results are close together so that check passes but obviously the numbers are dismally low. Did the test with a Harbor Freight US General quick disconnect kit. Not sure if the equipment or myself could skew the numbers but frankly, I feel like that is grasping at straws.
So I have an engine that tested poorly.
The question is... now what?
Was the engine warm when you tested it? Did you push the throttle open when you cranked the motor over? Next step would be a leakdown test to see how much pressure you are really losing.
I would bet you're fine. I have a HF oil pressure tester and it's gauge is way out of whack, so there's a good chance it may be the gauge. Like as said before there are certain things like warm motor, pulling fuel pump fuse,etc... That'll result in higher numbers. You're definitely consistent, so that's a really good sign.
Was there a reason you tested the compression on this engine? Were you experiencing poor performance? If not, I would try another gauge and see what it says if you're worried about low numbers.
One thing I noticed was that when screwing the hose into the engine it never got tight. Seems that the hose spins on the threaded piece. (Lacking vocabulary, I apologize.)
It looks to be by design, though I'm not certain. I did get it as tight as possible, though.
I decided to test it because it had never been done, to my knowledge.
I guess the next step is a leakdown test before I decide what to do about these numbers.
I'm guessing my options are pretty limited and somewhat ugly.
Buy, borrow, or rent a better compression tester if you're worried. Unless you the motor is of high mileage, abuse, or your were missing performance, I wouldn't worry about a leak down tester. To make you feel better about the low numbers, a non HF setup may test more accurately and get rid of the crappy gut feeling your probably have.
SpaZilla
05-04-2006 01:04 PM
