Compression Test Result
Old 09-02-2010, 01:02 PM
bd307's Avatar
I am burning a little over a quart every 2k miles which I think is reasonable.
It does not burn oil that I notice on track for 5-6 sessions the whole day in hot weather (95 hot).
Old 09-02-2010, 01:03 PM
bd307's Avatar
I am bringing the car to another place for compression and leakdown today. I am hoping the previous guy did not do the proper compress test, or I am worried for forking out for a longblock (3-3.5k) with install -_-
Old 09-02-2010, 09:10 PM
bd307's Avatar
Here are some good news.
Just came back from another technician for 2nd opinion. I was glad I did that and the compression reading is 240, 245, 245, and 245.
It is higher than most motors as the tech suggested the previous owner installed a thin 2-layer head gasket and may even have installed flat valves.
He also did a valve adjustment and my motor is running very smooth and strong now.
Thanks for all comments and hope this helps anyone.
Old 09-03-2010, 08:37 AM
nsxtasi's Avatar
Why would one place read one number and another place read another number that is no where near your first number. Maybe get a third test so we really know what the actual number is
Old 09-03-2010, 09:56 AM
bd307's Avatar
I trust this 2nd tech more than the previous. He has worked on many s2k and a lot of socal peeps go to him.
Old 09-03-2010, 09:57 AM
rosscoe21's Avatar
Was the car up to operating temps, if not that will make it read lower.
Old 09-03-2010, 10:04 AM
camuman's Avatar
other tester might not have floored the go pedal when he tested it.
as for higher then normal, noone that goes turbo will riase compression on an already high compression motor. adjusting the valves def coulda helped too.
Old 09-05-2010, 04:43 PM
bd307's Avatar
I did not know the temp when the first tech did compression on my car as I was not there, but the car was definitely on operating temp when the 2nd tech did compression on my car while I was there.
We suspected the previous owner blew the piston rings or even the valves from turbo'ing it and while fixing and replacing parts, he replaced with flat valve and thinner layers of head gasket. That leads to our conclusion of why the reading was this good.
Old 09-07-2010, 08:31 AM
mad pup's Avatar
Cool, thanks for the info. That's about how much I burn too - a quart every 2K. I guess it's par for the course for F20s.
Glad to hear your compression test gave good results!
Old 09-07-2010, 02:53 PM
bd307's Avatar
Yup, I am all happy and it is very smooth with the valve adjustment too!
darkvette07
07-01-2017 05:01 PM
jdblood202
08-09-2014 06:43 PM
S2K Sideways
05-03-2009 04:42 AM
Ztec
10-13-2005 03:34 PM
Quick Reply: Compression Test Result
