Compression test done AGAIN, UPDATE 11-21-05
Old 11-05-2005, 07:52 PM
Asura's Avatar
Sounds like scoring on the cylinder wall to me.
Old 11-05-2005, 08:11 PM
fperra's Avatar
Originally Posted by Slows2k,Nov 5 2005, 10:02 AM
Do a leakdown test. Chances are #4's rings aren't sealing as good anymore.
Due to intake manifold design, and placement in the engine compartment #4 runs leaner and hotter than the other cylinders.
You got that right on cylinder #4. If you have the AEM EMS you can adjust the fuel in each cylinder individually, and I would highly recommend this to everyone. Read your plugs and adjust acordingly. I have an additional 7% fuel trim in #4 and 2% in #3. It took a while reading the plugs until I got them all burning about the same.
Old 11-05-2005, 09:26 PM
Asura's Avatar
Is there a way to quantify this without putting an EGT sensor in each exhaust runner?
Old 11-05-2005, 09:34 PM
f20kills's Avatar
I am going to do a leak down test this week.
The thing is though, the #4 cylinder plug was always black compared tot he rest.
My guess is that my timing got things too hot(3 degrees total at 5000 rpm, 10psi which I fixed when I saw it).
My car has always run good so I hope its just a valve seal thingy..
Asura would scoring cause the car to run like crap or would I never know.
Old 11-05-2005, 09:49 PM
Asura's Avatar
Depending on how bad the scoring is, you would be getting a lot of blow by which would explain some of your oil consumption and black plug.
Your leak down % will also be greater in the 'bad' cylinder. It could be due to a worn ring or a scored wall.
From my experience, if are monitoring your AFR, it will be all over the place if indeed your walls are scored.
To be safe, I would have a peek with a bore scope and check the wall condition on the driver side of the block. This is the 'upstroke' area where scoring is most likely to occur, check the entire cylinder though.
The leakdown test and bore scope are the most useful diagnosis tools to get a good idea without pulling the head.
Old 11-05-2005, 10:07 PM
f20kills's Avatar
Thanks
My a/f is always the same and is never all over the place.
When I first get on it the car does let out a puff of smoke but none after that.
I will keep this post updated.
Old 11-09-2005, 09:12 PM
f20kills's Avatar
I was reading the manual and realized that the max variance is 28psi, not 15 like I had thought.
I still have an appointment for a leak down test.
So those who might still be interested I will post the results.
Old 11-21-2005, 12:12 PM
f20kills's Avatar
UPDATE for those interested on first post.
Comments welcome.
RHDS2K
05-01-2014 09:24 AM
fltsfshr
07-27-2009 07:26 AM
S2K Sideways
05-03-2009 04:42 AM
Ztec
10-13-2005 03:34 PM
Quick Reply: Compression test done AGAIN, UPDATE 11-21-05
