compression test
compression test
i just did the copression test on my s2000 and it came as this
1#195
2#180
3#178
4#178
this test was done when the car was cold and sitting at my garage for 2 days.
1#195
2#180
3#178
4#178
Just like a dyno sheet, do not get hung up on the numbers by themselves. If you had a huge disparity between one cylinder and the rest, that would be of concern. Do as the above gents said and re-test.
Originally Posted by s2kbtos,Feb 29 2008, 04:21 PM
the plugs were out but i forgo to take out the fuse and i didn't press on the gas pedal. i will try to do it tomorrow.
Not removing the fuse is NOT good (in other words, it's important to remove it)
If the fuse is left in, fuel is sprayed into the cylinder during cranking, washing the oil from the rings yielding lower comp numbers.
Moddiction
06-20-2008 08:53 AM
