Compression in our engines...
What should the compression be in our cylinders??? I recall someone saying it should be within 180-200psi and all 4 cylinders should be within 10% of each other...is this correct???
Just had mine checked when my mechanic did the plug recall. Wanted to see how it broke in and make sure the #4 cylinder was not wearing. Lowest 225 - Highest 230. Had the valves done at the same time.
Originally posted by S2K
Is a compression test the same thing as a leakdown test???
Your cylinders should always measure within about 2-5% of each other, anything in excess of about 10% indicates a problem. Anything that is 10% lower than stock also indicates a problem. The results of a compression test generally go up with age (on a car in good health) as the carbon deposits on the piston usually increase compression slightly.
Compression on a brand new motor is usually lower, due to improper (incomplete) sealing of the rings. Anything below maybe 7,000 or 8,000 miles will be lower.
The results:
Cylinder #1 = 261
Cylinder #2 = 255
Cylinder #3 = 255
Cylinder #4 = 255
All readings were performed twice on each cylinder, and compression test was performed in manner mentioned above: Pulled all plugs...pulled fuel pump fuse...and with clutch & gas pedals all the way to the floor, cranked the motor over numerous times [actually my mechanic cranked it 12 times per cylinder check as that is his SOP at the Honda shop] testing one cylinder at a time.
I plan to perform this test again with a different compression gauge (sort of an 'objective' testing if you will) to assure his gauge wasn't faulty, etc.). I'll try to report back here again once I do that.
Overall, I'm very pleased
- Dave
Elistan
09-07-2012 08:22 PM
Moddiction
06-20-2008 08:53 AM
