Compression numbers for AP2 looks too good... seems fishy
Old 12-12-2014, 08:40 AM
1SlowSi's Avatar
My F22C had 250,253,251,258 and settled down to 248, 240, 251, 245
Old 12-12-2014, 11:15 AM
liloutlaws's Avatar
Was that when it was brand new? What are numbers like when they are completely new?
Old 12-13-2014, 02:39 AM
CoolGuy094's Avatar
OP - Science of Speed is one of the most reputable vendors/shops for S2000's in the market right now. I would trust data with their name on it.
Good luck with your purchase, sounds like a healthy motor!
Old 10-16-2015, 11:17 PM
subwayasian's Avatar
This is interesting. My 06 ap2 s2k with about 120-130kish miles came out with 240-250 across the board. guess my engine is healthy.
Old 10-17-2015, 04:47 AM
Car Analogy's Avatar
Received 1,470 Likes on 1,086 Posts
Originally Posted by liloutlaws
Once numbers go down, can you maintain it to bring it back up? Or can you only do that w/ a new engine?
Seriously? Its not like your body where you can get your cholesterol down by eating right and exercise. Engines don't heal. Wear is wear.
Compression is a test of how well the cylinders are sealed. Piston rings, valves. If there is wear, and these things don't seal properly, numbers will be low.
The only way to get numbers to go up is fix what is worn. New rings, valve job, etc. An engine rebuild, if engine still can be rebuilt (our engines are more difficult to rebuild than most, FRM cylinder liners, multiple possible bearing sizes, etc.)
Sent from my SM-G920P using IB AutoGroup
Old 10-18-2015, 01:20 PM
Greyout's Avatar
If it's slightly down, there are oil additives that claim to help rings re-seal.
darkvette07
07-01-2017 05:01 PM
RHDS2K
05-01-2014 09:24 AM
josh7owens
09-30-2012 07:50 AM
ZachP51
09-17-2012 08:28 AM
kmengys2k
05-03-2010 01:16 PM
Quick Reply: Compression numbers for AP2 looks too good... seems fishy
