Completely Dead
Old 11-04-2017, 03:58 PM
AZS2KDancer's Avatar
Default Completely Dead
I am getting absolutely no power to interior lights, dash, or anything, and the S won't even turn over. I put a battery charger on it, and it's registering full. What can I check next? It simply doesn't turn over at all.
Old 11-04-2017, 04:06 PM
starchland's Avatar
Assuming you checked all the fuses, do you have a volt meter?
S_DosMil's Avatar
Acg fuse? Main relay? I would start will all fuses under hood and dash.
Old 11-04-2017, 04:31 PM
I'm going to start pulling fuses. One box near the battery and one box in driver's footwell that I know of. Any others? I do have a voltmeter.
Old 11-04-2017, 04:50 PM
Noob question. How do I remove the cover for the under dash fuse panel? Main fuse box: Pulled fuses that I could not see from above. All look OK. Obvious that there are some larger black fuses that I cann't see into.
Old 11-04-2017, 05:07 PM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Check the main 100a fuse, under the hood. Held in with 2 philips screws.
Old 11-04-2017, 05:18 PM
The first Phillips screw I tried is really stuck on there. I'm afraid I'm going to strip the head. What size socket driver will fit that? 10mm?
Old 11-04-2017, 05:30 PM
the 100 A fuse looks good.
Old 11-04-2017, 05:31 PM
The battery is reading 279.5 VDC.
Old 11-04-2017, 05:40 PM
honda4eva89's Avatar
The battery is reading what??!! It should be around 12.6V I hope
Quick Reply: Completely Dead
