Cold weather clutch/gearbox issues
Old 11-26-2013, 04:48 AM
iamxpl's Avatar
the seals wear out over time. glad to see you got it fixed and you posted back. HOORAY!
Old 11-26-2013, 09:45 AM
Spindash's Avatar
Yep, it's the seals on the cylinders. I might also add that I change the fluid in the clutch fluid reservoir every 5,000 miles or so. It keeps the shifting much smoother and prevents all the dirty fluid and sludge buildup that is common when the fluid is neglected. Good habit to be in.
Old 11-26-2013, 10:01 AM
s200000's Avatar
Ok I will do that for now on. Should I replace both the master and slave cylinder ASAP?
Old 11-26-2013, 11:35 AM
freq's Avatar
NO!! Keep an eye on them but I personally wouldn't.
Old 11-26-2013, 12:58 PM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
90% of s2k CMCs leak.
Suck out the fluid in another 1000 miles, clean out the res spotless with paper towels, fill it back up, leave 3/8" of space on top for the cap to fit.
Do it every 5000 miles thereafter. You have a 95% chance of stopping the leak.
I have only needed to replace 1 S2000 CMC in over 1100 cars.
Old 11-26-2013, 03:02 PM
s200000's Avatar
So if I do that I can stop the leak? So what was causing the leak in the first place? The sludgy build up?
Old 11-28-2013, 10:17 PM
2003AP1's Avatar
I make changing out the clutch fluid on my car a habbit at least once every season.
stwoki
02-24-2011 07:15 AM
BlackBearTX
11-24-2010 10:02 AM
amdaman
11-21-2009 02:15 PM
jstar
01-06-2007 05:27 AM
s2kpr01
08-12-2006 12:54 PM
Quick Reply: Cold weather clutch/gearbox issues
