Cold Start Fine! Warm Start Not!
Happy Halloween everyone!
So in a cold start my S2000 starts fine. So when I drive to my destination, park and then when I leave, my S2000 doesn't start right away. I push and hold the start button about 3 to 4 times longer than just a push to start.
This has happened twice. Why is that? Thanks, I am getting concerned!
Check your fuel injection system pressure at the fuel injection manifold. The readings on a cold start and warm start should be nearlty the same. If the warm start readings start at zero, the accumulator or fuel pump check valve to maintain fuel injection system pressure may be faulty or the fuel pump may be failing.
have you fixed it?
Mine just happened today and I had to tow it home.
I want to the below, but there's no photos anymore.
https://www.s2ki.com/forums/s2000-un...utton-1092241/
DIY: Clutch Interlock Switch Bypass - S2KI Honda S2000 Forums
have you fixed it?
1. A was connected to B (note position of Fuse Box)
2. Jam something like this into A to short it. I glued it to Fuse Box for easy access in future
