Coil welded itself to spark plug tube
Old 05-09-2012, 10:26 PM
fantas's Avatar
i Have that issue yesterday. what cause it? what have you done to fix that?
Old 05-10-2012, 06:27 AM
cadams05nfr's Avatar
Wow reminds me of Cobra's that had the plugs shooting out of the head. That pic of the cylinder head sure shows there are not many threads holding these plugs in. I guess thats why they make it so clear to torque the plugs to spec on a stone cold motor huh. Will keep this in mind for sure!
Old 05-10-2012, 06:47 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Improperly tightened spark plug is the cause. 100% without question
Old 05-10-2012, 09:11 AM
Voodoo_S2K's Avatar
I think my Helm manual had the old tq value in it and I forgot there was a revised spec.
Old 05-10-2012, 09:50 AM
Pinky's Avatar
Originally Posted by Stealth_SUX_
Originally Posted by Voodoo_S2K,Jun 10 2008, 03:13 PM
Been there, done that.
Yep it was a loose spark plug...
Question though, what did u guys do... I was able to get it all out.. but did you guys end up removing the head..
I was planning to do a compression test and remove the head if its bad.. But i didn't want to remove the head if i didn't have to..
My other question is there are bits of peices of the coil pack on the valvetrain.. I cleaned it up but Im worried what if there are stuck peices in the oil passages...
Ima drop the oil pan and clean that up.. Any other suggestions...
It wouldn't be in your valve train. It would have passed through the exhaust system if anything. Compression test is good. Depending on what fell in there it might have scored your cylinder walls.
Good Luck.
NotaMechanic431
06-08-2016 09:56 PM
moneyman s2k
Inland Empire S2000 Owners
20
11-30-2008 06:17 AM
Puppy
09-08-2008 12:50 PM
Stealth_SUX_
06-20-2008 04:46 AM
heresnowhy
08-27-2007 01:43 PM
Quick Reply: Coil welded itself to spark plug tube
