clutch worn or what? please help
My friend checked his clutch fluid level and it was way below the Minimum level, car revs but the speedo does not move at all, I mean he revs it all the way to 6k rpm,steps on the clutch put in in 1st gear and the thing doesnt move. We filled the clutch fluid up and it finally moved only thing is it can only go up to 10 mph tops, Any suggestions on whats worng with it before bringing it to a mechanic?..many thanks
But that's not the problem since you use the clutch to disengage. With no fluid the clutch would remain engaged at all times.
Are you sure it's in gear? If so sounds like the clutch disk is shot.
Originally Posted by Wisconsin S2k,Apr 9 2005, 01:18 PM
clutch master cylinder maybe?
Originally Posted by GpLhenS2000,Apr 9 2005, 01:26 PM
does that mean its only a minor replacement? or is it the whole clutch?
It probably wouldn't be a bad idea to replace the tranny at this point in time either. Maybe the piston return springs as well. Shit, you should replace the wheel bearings as they have a direct correlation in the smooth proper function of a good operating clutch.
donkeykong
01-11-2007 11:59 AM
