Clutch wont engage at all (car wont start)
Hi folks,
-02 ap1
-clutch was replaced by a trusted mechanic less than a year ago
-was on highway accidentally downshifted to second but i caught it in time (didnt over-rev)
-shortly after noticed strange loud sounds when the clutch was engaged (sounded like a yhetti)
-checked master cylinder it was low so i filled it back up
-drove it for 2 days with strange sounds clutch behavior was normal
-drove it this morning to auto parts store
-leaving the store, started the car, hit the clutch to put it in gear, clutch hit the floor
-manually brought clutch back up, turned the car off and now the clutch pedal wont move at all
-1-3 inches of play then it feels like it hits a brick wall (clutch wont engage, car wont start)
I got the car towed its sitting in the garage I'm planning on putting it on stands and taking a look at it before
I send it over to the mechanic
Any suggestions on what I should look for?
should i bleed the clutch?
Thanks for reading any input will be appreciated.
Have a great day.
-02 ap1
Have a great day.
Off-hand, it sounds like a throw-out bearing and/or pressure plate issue. Were these items inspected and replaced (if necessary), when the clutch plate was replaced?
I polished off the cylinder rod... Clutch wouldnt depress... Bled the clutch fluid with the help of my beautiful girlfriend and the pedal finally moved. I can now start the car but it doesnt go into gear when the car is on. Started the car in first and the car stalled. Anybody ???
Maybe your slave is shot, they're pretty cheap.
