Clutch vibration help please!, not typical buzz
I recently purchased my s2k, 35 k miles, very good condition. Just recently my clutch pedal started vibrating on high rpms.
For example: if i press clutch pedal all the way in, rev to 7k while still having the pedal all the way in, i can feel a vibration through my pedal. Its a very fast vibrstion that almost makes my foot tingle. Any advice would b greatly appreciated, especially if tbis is something that could cause other issues.
Sent from my SCH-I535 using Tapatalk 2
First thing that comes to mind is adjust the clutch pedal. If the clutch isnt disengaging all the way it could cause the vibration your feeling.
There is a rod with an adjustable locking nut on it that goes into the clucth master cyl. You crack the nut loose and then spin the rod to adjust the play in the clucth pedal.
https://www.s2ki.com/s2000/topic/275...ge-this-early/
Half way down that thread are some nice pics and instructions.
If this does not fix it, maybe you need to regrease your pilot/throwout bearing. Throwout you can do with the transmission still on the car. Just need a grease gun and a flashlight.
Lastly and i hope its not this, but you can measure the ammount of crank thrust when you press the clucth pedal down. If your thrust washers are bad it will cause the crank to "walk" towards the front of the engine when you press the pedal down and then it will oscillate causing the vibrations.
To check the thrust you can grab a gauge from harbour freight with a magnent on it. mount it somewhere in your car and place the tip on your crank pully. Then have someone press the pedal down and see how far the crank moves. I forget what is an acceptable ammount but im sure someone will chime in soon.
Hope some of this helps.
Pushing the pedal down is not a good way to check the crank thrust, because there is nothing to return the crank to the forward position once the pedal is released and you will not get a proper reading.
I would immediately measure the crank thrust by moving the crank in and out all the way by hand. If the bearings get bad enough, they will destroy the entire engine, crank, rods, even the block.
BTW free revving an engine while not under load is a bad idea.
