Clutch or Transmission Issue?
Just recently, about a couple months ago, I started to realize it's been extremely difficult to get into reverse gear. I literally have to use both hands and pull down for it to pop into reverse. Also, despite depressing the clutch entirely, I feel a grinding sound when put into first gear when the car is going around 5-10 mph. And now, each gear shift has difficulty putting into gear. I've had to use much more pressure to put the car into each gear. There is no grinding noise in any gear other than 1st and that only happens when the car is moving slow enough to be in first gear.
I thought it may have been the transmission fluid, but I recently had the transmission fluid changed by my local Honda dealership.
I'm afraid that by using so much force to put it into reverse or any gear for that matter that it will either damage the clutch or the transmission.
So my question is, is the clutch the issue or the transmission??? Please help!!
Try adjusting the clutch rod. You don't want too much excessive play in it. Its right behind the clutch pedal. Rod sticking through the firewall into the master cylinder. There is a diy on the forums somewhere. Google it I'm on my phone right now so I cant provide the link.
Edit: also check your clutch fluid in the master cylinder reservoir under the hood on the right of the brake reservoir (closest to the fender) and make sure the fluid isn't dirty muddy color.
Edit again: has it always been hard to pop into reverse? Just throwing it out there, but you do know you gotta push the shifter straight down to unlock the safety mechanism right?
Sent from my SGH-T999 using Tapatalk 2
Every time you have to "pull" the shifter to get it into gear the transmission is screaming in pain. Your blocking rings hate you and eventually they will give up resulting in a new or rebuild trans. It sounds as though your clutch is not disengaging fully. Whether that is a mechanical disc or plate failure or a hydraulic problem either way it needs to be fixed asap before your trans is toast.
I would do the easy thing first before thinking its the transmission. Personally I'd pop the top on your clutch fluid master cylinder. Literally a 2 minute job if that. If the fluid is dirty then baste/soak up the old fluid and wipe the resivior out and add clean fluid. It could be as simple as that. Chances are depending on how long you had the car if you haven't changed the clutch fluid it will feel a lot better just after this step. If its still not right I'd adjust the clutch rod.
Do the easy things first, these cars are easy to work on
If you've been just popping your car into 1st at 5-10mph all the time without double clutching then your syncros are done and thats probably why its so difficult for you to engage first and reverse. Since if i remember correctly reverse and first are straight cut gears and non helical. So if your syncro is blasted apart, it may have gotten stuck on the teeth on the cones?
I bent down and took a look at the master cylinder and it looks like there's a leak? A black thick fluid is seemingly leaking out. Looks like I need to replace the master cylinder. Would I need to replace the slave as well?
The Master cylinder is the reservoir under the hood in the engine bay. The slave cylinder is the part that is bolted to the transmission. They are connected by a hydraulic line. Which one did you look at? Like other have mentioned you want to see what fluid you have left in the reservoir first and see what color it looks like.
This is a picture of where the clutch master is
Take a look and let us know what you find
That's what the fluid looks like. It definitely does NOT look as clear or anywhere near as full as it should be. So now I guess my issue is, do I drain and fill it up first (if so, what kind of fluid is recommended?) or should I be more worried about the leak near the clutch rod and get that taken care of while I'm at it?
