clutch/tranny question
Old 05-19-2006, 12:03 PM
  #21
kuuligan's Avatar
Originally Posted by mbilderback,May 19 2006, 11:51 AM
BTW, the ~800 is for the clutch, flywheel, throwout, and pressure plate.
i need to replace all those at the same time?
Cant i just replace the clutch? sorry...i'm not so experienced with transmission related
Old 05-19-2006, 12:33 PM
  #22
xviper's Avatar
Doing a clutch job on this car is a major piece of work. It involves dropping the engine (a lot needs to be done before you can do this) and removing the transmission. When you're all done, you will have to get a wheel alignment. The work itself will cost many times more than a clutch disc itself.
No, you don't have to replace "all" that stuff. You can cheap out and just get the clutch disc and shove a bunch of horseshoes under your seat for good luck and hope none of the other clutch parts go. However, on the original clutch at nearly 100K miles, you can be fairly sure that the flywheel, pilot bearing, TO bearing and pressure plate are long for this world, so quite soon, you would be dropping the engine, taking the tranny off, getting another wheel alignment when you have to replace those other parts. Do you feel lucky?
Oh, and I've mentioned once already about the clutch fluid and someone else has even re-stated it. If you choose to ignore that bit of information when you're most likely dealing with original clutch fluid, that's also your choice.
Old 05-19-2006, 01:01 PM
  #23
kuuligan's Avatar
ah ok. So i need to inspect the clutch fluid? Or do i just replace the clutch fluid.
What color is it and how do I tell it needs replacing?
thanks again
deanbayley
04-04-2012 09:54 AM
01Ap1S2k
01-25-2011 01:41 PM
1999
Bay Area For Sale
12-06-2010 06:46 PM
genghiskwong
12-23-2002 01:49 PM
Quick Reply: clutch/tranny question
