clutch/tranny question
Old 05-19-2006, 10:23 AM
kuuligan's Avatar
Originally Posted by darkfx,May 19 2006, 09:09 AM
He said CLUTCH FLUID CHANGE.. not tranny or diff...
reading > me
Old 05-19-2006, 10:47 AM
xviper's Avatar
OK, I think we're dealing with two different topics here. If I understand this correctly (a better explanation would have gone a long way), you are pulling the shifter OUT OF GEAR yourself, without using the clutch, right? This is completely different from a gearbox that "pops" out of gear on its own, which is NOT a good thing. You are MAKING it come out of gear by choice and thus, has nothing to do with a good or bad tranny; good or bad clutch.
This is NO SURPRISE! It can easily be done. Taking the tranny OUT of gear without the clutch is nothing new. EVERY transmission can do this. In fact, if the revs are matched precisely, you can also put it INTO gear without use of the clutch, although neither is recommended due to the risks involved.
The above is NO indication of clutch condition. The key points that should direct you toward the clutch fluid is the statement that the friction point is rather high on the pedal travel.
As for whether or not the clutch is worn and needing replacement is a whole other set of tests. Let's get one thing straight before diving into something else that may or may not be related.
Old 05-19-2006, 10:58 AM
kuuligan's Avatar
yes, that is correct. My tranny is not popping out of gear randomly. It can move out of gear when I pulling it out.
This is good news, my tranny is ok
The only question i have left is whether or not its time to replace my clutch. Its at 92k miles on the original clutch. The pedal engagement point is rather high which typically leads to a worn out clutch.
My other question is wouldnt a worn out clutch cause the clutch to "slip" when changing gears? My friend needs a new clutch and he knows that its worn because when shifting aggressively, clutch does not grab right away. With my clutch, it grabs pretty good still.
sorry if i caused much confusion earlier
Old 05-19-2006, 11:11 AM
mbilderback's Avatar
My clutch (I'll get pictures) was VERY worn, very nearly hitting bolts. It never slipped once. Don't rely upon slippage to determine when it's time to change the clutch.
Old 05-19-2006, 11:18 AM
Eluded's Avatar
kuuligan, some would have gone thru three or more clutches in just 90K.
Old 05-19-2006, 11:21 AM
kuuligan's Avatar
ok, its pretty much confirmed my clutch is worn then.
What sort of clutch is recommended? how much would it cost to replace, laborwise.
thanks!
Old 05-19-2006, 11:23 AM
You can order from the S2ki Marketplace and Hardtopguy.com. Expect to spend ~800 if you do it yourself or ~1500 to ~2000 if you have a reputable shop do it.
Old 05-19-2006, 11:45 AM
toeknee's Avatar
kulligan, time for a DIY
Old 05-19-2006, 11:49 AM
kuuligan's Avatar
omg...800 bucks for a clutch?
I think my 6 puck clutch on my turbo lex cost like 400 bucks
tony...wanna chnage out clutch same time as me?
lol
Old 05-19-2006, 11:51 AM
BTW, the ~800 is for the clutch, flywheel, throwout, and pressure plate.
Quick Reply: clutch/tranny question
