Clutch/ Tranny?
Clutch/ Tranny?
So about 5k miles ago i had my clutch replaced just because it was out anyways due to bad synchros so i took advantage of not paying any extra for labor. Anyways at first the car ran great no problems but now all of the sudden i hear what sounds almost like a grinding noise coming directly below the car where the tranny would be when driving. It does not do it when idling only when it is moving and the noise increases with speed.
no its stock. But yea its like a kind of grinding wine its hard to describe and it gets louder with speed im starting to wonder if it might be my flywheel.
Stating the obvious hereid ya re-surface the fw and put in new pilot bearing?New pressure plate? You had a shop do it? And they replaced the syncho's?
It was done at the honda dealership and it was going in because of the 1st/reverse gear synchro and since they have to pull apart everything anyways under warrenty i would have them do the clutch since i wouldn't have to pay for labor so in short i don't know what the dealership did. Im taking it that i should probably have it looked at again.
HvRRZ
01-16-2006 03:26 PM
