Clutch Replacement.... Parts Question (bearings, and what not)
About to order everything I need for the clutch replacement.
I did the research and going with the OEM disk from Honda, and the H021 Pressure plate from ACT.
Do I just go ahead and order all the parts off the Majestic site under the tab for "clutch" with exception of the pressure disk? I see the pilot bearing, but no designation for throw out bearing?
22200-PCX-055 002 001 DISK, FRICTION 176.15 123.31 Qty:
90011-PCX-B01 004 008 BOLT (12MM) 5.02 3.51 Qty:
90034-689-000 005 009 BOLT, TWELVE POINT (8MM) (TOKAI TRW) 6.45 4.52 Qty:
90429-PCX-000 006 001 WASHER (38X88X2) 14.37 10.06 Qty:
91006-PCX-008 007 001 BEARING, CLUTCH PILOT 21.90 15.33 Qty:
Sorry for the idiot question, never done a clutch replacement in my 28 years. First time for everything but I would rather have everything on hand then figure it out later. Also, is there anything else recommended to do while replacing the clutch? Rear main seal?
Im not doing it. Never done a clutch before and not trying to learn through mistakes on this one. Just want to make sure I have all the parts on hand. Local fella that runs his own shop is doing it.
Thanks for pointing me in the right direction.
Sent from my SM-G920P using IB AutoGroup
Received 1,375 Likes
Release bearing guide is a must also
coop3422
04-03-2016 04:52 PM
