Clutch replacement.. DIY? aftermarket winners?
#112
Originally Posted by revto9k,Dec 6 2004, 02:00 PM
simply no, DIY clutch change is impossible unless you have a lift, and extra helpping hand. You need to drop the tranny, taking it off is the easy part, putting it back together is the hard part. You have to allign everything properly.
#113
Originally Posted by gernby,Dec 1 2004, 09:03 AM
Would Valvoline Semi-Senthetic Dura Blend grease be sufficient?
fperra, PM sent.
fperra, PM sent.
#114
Originally Posted by gernby,Dec 6 2004, 06:58 PM
You didn't read the whole thread, did you?
#115
Originally Posted by fperra,Nov 30 2004, 08:41 AM
Gernby: I've dropped the tranny and changed the clutch and flywheel twice, and managed to do it all on my own. If you need help, let me know. I've also got the flywheel locking tool if you want to borrow it. Let me know. I'll be in Mexico on vacation the last two weeks of December though.
On another note, if you want to stop by this weekend you can pick up the battery hold down bracket.
- wanna help me install my clutch?
#116
Originally Posted by dut,Dec 7 2004, 12:41 AM
- hmmm.. im down by mexico and I have last 2 weeks off in december..
#117
#119
Have just started my clutch swap and immediately had problems with the drive shaft bolts. Most of them came out eventually but are badly burred. One I had to grind the head off with a dremel. So it's off to Honda for me on Monday. And I've still got Sunday left to break some more bits.
#120
Thanks Hecash. At first I was using a 6mm hex head on my rachet but the racchet isn't long enough to give the quick burst of torque required. I then used a breaker bar and that did the trick. But i can't help but think the bolt heads can't be in too good shape. I'll inspect and replace any that are damaged.
