Clutch Recommendation
#24
thanks, Yellow Streak, I scoured their site and found almost nothing in terms of technical data, I will look again, though, to make sure I didn't miss anything......
I have never heard a bad thing about exedy clutches, which make me very interested and I think the price is pretty good considering it comes with a flywheel, except I'm really stuck on that Toda flywheel.....
EDIT - yeah, I tried their site in two different browsers and it's pretty wacky.... at least they have a picture of the flywheel, it *looks* good.... I'll contact them through the site and see what they say, if that doesn't work I'll shoot you a PM.... thanks
#25
YELLOWSTREAK- I can weigh my Exedy setup as it is still sitting in the garage awaiting the install. Do I need a special throw out bearing for the install or should I at least get a new stock one from Honda?
This setup can be purchased from David @R&Dmotorsports for a reasonable price for what you get.
I will weigh the flywheel and clutch after dinner. Phil
#26
phil - you rock!
BTW- I think 1200 for this setup is a little more than most other clutch setups, but it seems like it's worth it. The least I've seen for a combo that includes a flywheel was around 900.... so it's not so bad....
#28
[QUOTE]Originally posted by VTECPHIL#6829
[B]YELLOWSTREAK- I can weigh my Exedy setup as it is still sitting in the garage awaiting the install. Do I need a special throw out bearing for the install or should I at least get a new stock one from Honda?
#29
I didn't seperate the one piece unit, but as a WHOLE unit it weighs 21.5 lbs. I didn't know if this unit can be easily seperated, if it can be, I can weigh them seperately. Let me know. It is now moved under my bed-one step closer to install! First project is I missed a shift for a split second and blew the belt off the S/C, I guess when they say adjust at 250-400 miles they mean it! I had 392 on it and was going to get it adjusted the next day!
YS- I will probably less miles by the time I change mine out. I guess I should have no problems with my orig. bearing. Are you loving the clutch? Any noises or anything? Thanks Phil
#30
[B]I didn't seperate the one piece unit, but as a WHOLE unit it weighs 21.5 lbs. I didn't know if this unit can be easily seperated, if it can be, I can weigh them seperately. Let me know.
