clutch question/convex mirror inserts
Is there any simple tests I can do with out removing the tranny to see if slipping, I just got this car like 5 months ago with 7k miles on it , and i dunno if its me but it felt kinda different. Please let me know.
How do you reove the sideview mirror and plactic hosing on it? I don't wanna have to stcik the concave mirrors on top of. Thanks guys
When the engine and clutch are cold, rev it and drop the clutch in 5th and/or 6th (sitting still, e-brake on). If the engine dies, your clutch is alright. If the clutch slips, your clutch is fubar.
To remove the mirror and its plastic holder pull firmly from the top out and it will come loose. To remove the mirror from the plastic holder, bring a pot of water to a boil, then take the pot off of the burner. Lower the mirror and holder into the water for 20 seconds. Pull it back out and carefully push the mirror out from the back. The goop that holds it into the plastic holder can be reused to hold the new mirror in.
After you firmly pull from the top out...
-Drive/Call your closest Honda dealer to order the whole side mirror assembly..
-Pick up the order and then installed the new mirror.
From what I have heard. The clip is on the buttom and the hook is up top. Pull from the button out ...Otherwise, you'll rip the whole thing out, and possibly damaging everything behind it.
usmarinedelta
09-21-2015 07:56 PM
