Clutch Problems/Bleeding?
I have a 2002 AP1 s2000, i recently removed my engine and now having gotten the entire thing back in I am having trouble with my clutch. Trouble as is it is not pressurized at all. I am aware that you are supposed to bleed the clutch after having disconnected the slave master cylinder, but I do not know exactly what is wrong. We tried the old "one person pump and hold, the other open the valve, allow access to drain, close valve and release clutch" but that didnt work at all. The clutch just fell to the floor, nothing came out of the line, and the bleeder nozel actually came completely out. We put it back in before pulling the clutch off of the floor, but there is absolutely no pressure in the pedal after having pumped it at least 2-300 times... Does anyone know what I need to do, or if i have done something wrong, what I should do from here to fix?
Thanks for any help
Thanks for any help
