clutch problems
![Thumbs down](https://www.s2ki.com/forums/images/icons/icon13.gif)
i've had this clutch for the past 5 months now. for the past month i have had a bearing sound from the clutch and also the clutch pedal is like butter after i run the car a few times.
i tested to see if the car needs a new clutch , but it doesn't i pulled the ebrake as high as possible and let the clutch pedal go slowly and it doesn't move, also there is not slipping.
i want to change the bearing from the clutch. do you guys think i have to change the disc or the pressure plate? for the butter feeling, and can i put another brand of disc with the spec pressure plate?
I'm not sure I'm interpretting this "butter feeling" correctly. Can you elaborate a little?
Your method for testing the clutch doesn't seem to be a very good one (to me anyway). Your e-brake seems to be working fine though
. As for slippage, I would drive in 4th gear ~4K RPM and then hit the gas and see if it slips then.
If I have my e-brake fully engaged, my car wouldn't move when I engage 1st gear. It would just stay put and die as the RPM's fell.
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
the clutch pedal feels like really soft compare to when its cold.
the reason i tested like that its because before i even installed this 3 clutch my other clutch was going out so i was doing a research on how to test if its bad. so i did that with my old clutch and in first gear the car would just move with ebrake all the way up.
dollag2k6
11-19-2011 08:36 AM
