clutch problem
Check your clutch master first for fluid level and if it is very dark.
You can try to bleed the system and use a good semi synthetic dot 3/4 fluid. This is your least expensive and easiest to do thing first.
i am having the same problem and I am having a really hard time going into gear I checked the oil level is pretty full but it's kind of dark can you let me know if bleeding the fluid help it plus do you have hard time going into geras?? or am I having a bigger problem??
Thanks
Kyle
Thanks
Kyle
Thanks
Kyle
Thanks
Kyle
So I will get the fluid bleed out maybe this weekend so you think my cluch is still doing good then I am worry about the need of replacing my clutch but thanks S2KPUPPYDAD I will start with the fluid change first!!
Kyle
Kyle
All brake fluids are synthetic.
Just don't use DOT 5, that's silicone based and not for the S2000 brake/clutch system.
DOT 5.1 (notice the dot ) is compatible with DOT 3 and 4 and IS ok to use and surpasses the DOT 3 & 4 specs.
Kyle
Kyle
Spitfire is the man when it comes to fluid tech and info, very smart guy. I use the DOT 3 4 stuff because it works for me, the Vavoline is inexpensive and has very impressive numbers. I change the fluid when it starts to get a little dark about twice a year. Motor-Craft (Ford) also has a fluid that is outstanding and is much less than comparable products priced much higher
