Clutch Problem
Originally Posted by dbzerk,Nov 27 2006, 06:28 AM
humm
im thinking just the throw out bearing...
wonder if you can somehow lube it through the opening where the fork is...
Just found out today the clutch is slipping at high and hard RPMs... This would suggest its a faulty pressure plate? both the pressure plate and disc is brand new!!
:S
:S
IMO the clutch should not slip at high and hard RPM's.
When I go from 1st to 2nd to 3rd (with my 4.57's and shifting at the 4th beep) and use the clutch as an "on-off switch", (yes, I know thats hard on the driveline) it doesn't slip at all.
Even with warmed-up S-02's there is a little chirp going 1st to 2nd.
2nd to 3rd gives a bit of a "bang in the driveline", no I'm not shifting smooth.
OEM parts.
OEM parts.
Haven't had the chance to get under there yet , too busy.. Might have to take two days of from work and do it tho.. caar is feeling like crap
