clutch "popping" when pushed all the way in?
after bleeding my clutch, when I press my clutch in it "pops" almost when it's pushed all the way in...what's with that?
Sounds like you may have shoved a bit of air into the system. How did you do the bleed? With two people? With vacuum system? With pressure system? And when you finished and everything was topped up and bleeder screw locked down, did you give the pedal several good short pumps (like only the first couple of inches)?
the tech at our local Mod Day blead it for me with a vacuum suction .....when he finished he never said to give it short pumps but instead to just pump it......also, it doesn' t do it all the time....just sometime when i'm at a stand still.....is there any harm? ....I have never felt it while the car in motion
Although it is entirely possible that your condition is due to some other coincidental issue, until you do a proper bleeding, you cannot home in on what that other issue may be.
I do not seem to have any issues with my clutch.....until i bleed it again would you see any reason to be alerted? (in your opinion)
sn0wman
05-06-2014 05:43 PM
