Clutch pedal wont go down
Really? You got to be doing something wrong!
Clutch disk thick center part should be out.
The throwout bearing goes from the inside of the PP out.
When you get the tranny back in and engage the shift fork it should still move around on the pivot. (you should be able to look through the hole and see it around the throw out bearing.
When you put the slave back on it should push the shift fork tight against the throwout bearing.
Im going to go over and mess with the fork b4 work today.. think its bound up cause there is no movment at all.. I latched it in its spot b4 I had the tranny all the way bloted tight, so maybe that little bit was enough to mess it up
Got her working yesterday,un bolted the tranny on the bottom and got the fork out.. bolted it back up and put it back in and worked good.. new engine runs great, now I haft to figure out y my windows and top wont work and my windshield wipers guess my ac comp no good cause i recharged it and no cold air also.. no not driving this untill i can get ac or windows down lol 90 degrees black car no windows or ac = oven
I had clutch problems too, when swapped my engine.. and I am still having !!
I spent all my money in my new motor and garage's cost and now the clutch is completely disengaging disk with only 20% push..
The rest 80% of pedal's movement to the floor does nothing..
As a result the clutch that before the swap was working just great with only 10k miles on it, now it spins and working in a real "high" position..
I also created a topic here, couple days before, and not even one answered..
https://www.s2ki.com/s2000/topic/856...ird-lately-ii/
I'm going to set it on fire soon!!!!!!
