Clutch pedal STUCK! Help?!
#51
Originally Posted by RolanTHUNDER
Thanks for the info. How would I know if I buy an ACT that its newer than the old one with that issue?
I have a supercharger installed but should be getting a brand new OEM clutch kit installed. How well do you reckon it'll manage with the power? How good is the clamping force?
The splines rusted because previous clutch they didn't grease it. Causes crunchy shifts, as the clutch drags.
Copper grease, I don't know if that would work. Many have had issues using the wrong grease. If its too 'viscous', it will cause clutch drag.
One problem here is our cars are much more sensitive to this than most. Meanwhile mechanics that have done many clutches on other cars assume they know better than you. Rhey wanna go with what they know has worked on every other car. Convincing them to do something untried, to prevent a problem they don't believe exists, is not easy. Many a clutch job has turned out bad because of mechanic, who then insists, INSISTS he is not to blame. He knows he did it 'right', but he is wrong...
#52
What do you know about Exedy stage 1 clutches, Clutch Masters FX100/200/300, Spec stage 1 or 2?
#53
Exedy = crap
#55
Is it true that the OEM kit is actually made by Exedy? I've read that elsewhere online.
By right driver, do you mean one who never drives his S2000 like an S2000 is meant to be driven? (spirited, race now and then but never abused)
#57
Never expected Exedy to get such a bad review from an experienced mac like you. Makes me really want to stay away then.
But by putting oem in the name, it dupes a lot people into thinking they are the oem supplier. They are taking advantage of the fact it that it is often the case you can buy the exact same part as oem, for much cheaper, by buying directly from vendor that makes it. So it tricks people into thinking Exedy is the oem supplier. Nothing could be further from the truth.
But the trick works. People get fooled.
Buyer beware.
#58
FCC is the oem maker of the clutch disc. Not Exedy.
The right driver means operating the car correctly. Whether driving wide open on the track or slow around town doesn't matter. The right driver will enjoy the car every day on the track, the wrong driver will wear out the clutch in 10k gentle miles around town.
I did my ACT pp and oem parts at 10k. Now at 145,000 and it operates like brand new. And its all track and Dragon miles.
Of the many broken Exedy kits I've pulled out, the customers have all stated there was less than 20k on the clutch. The T/O bearing will fail at 20k like clockwork. The disc will buzz right out of the box, and the springs will beat themselves loose.
The Exedy disc also looks nothing at all like the oem FCC disc.
The oem PP is also indestructible, if you don't get the ACT pp.
#59
I had a exedy hyper stage 3 clutch kit installed with a vortech supercharger. This clutch was too stiff and the flywheel was too light for my ap1 used for city driving only. I swapped it out with the ScienceofSpeed Sport Clutch Kit with 11.5 lb Lightweight Flywheel and ScienceofSpeed Stainless Braided Clutch Hose. This kit is a little stiffer than the stock clutch, some more clutch noise and the flywheel is just right for city use. I'm happy with the scienceofspeed parts and other people that have driven the car also like this kit.
#60
Buyer beware.
Still for an S2000 one has to be even more careful when choosing clutches. Don't want to get duped especially since many experienced bad things from an Exedy.
