Clutch Pedal Sticking / Notchy
Old 11-15-2014, 10:40 AM
  #21
Acethriller's Avatar
Originally Posted by Cristian Tita
had the exact same issue, no squeaking or anything, would stick down low, would be better after spirited driving.. but didnt last.
did the slave cylinder rod polish and grease but didnt help.
what did help was Billman's advice:
Fork tips need grease where they contact the TO bearing. Not easy to get at, but you can reach in there with a coat hanger and dab grease on each tip.
Unbolt slave and remove boot of course, then disengage fork and grease it.
this might not be a permanent solution. i had this done once, it was good for about a month or so then turned to crap again.
i had the mechanic do it again this time with high temp urea grease and it's been running smooth for about a month now. fingers crossed it stays like this.
i'd say try it and see how long it lasts. reading the forum it seems it works for good for some and temporarily for others.
still worth doing before dropping the transmission.
cost me 40 bucks at a mechanic but its a DIY if you have basic tools and a way to lift it.
good luck man!
Cristian
Sorry but kinda confused what fork you're referring to, is that not the rod in the master cylinder? Would you be able to direct me to some photos of where the fork is? thanks.
Old 11-15-2014, 03:42 PM
  #22
dagle's Avatar
He means the Clutch fork that operates the throwout bearing. The fork that goes inside the transmission.
Old 11-15-2014, 03:50 PM
  #23
mikefifth's Avatar
Can someone supple a photo of what needs greasing please. I can pull the rubber boot and the push padel thing and look right inside the clutch part. But no idea what to grease
Old 11-21-2014, 01:28 AM
  #24
mikefifth's Avatar
AnAnybody? Please!!
ookielookie
09-18-2010 09:18 AM
Koski
07-30-2008 11:14 PM
Pezza
11-27-2007 10:15 PM
WtbS2k
06-01-2006 08:23 AM
ajkewler
01-09-2006 11:36 AM
Quick Reply: Clutch Pedal Sticking / Notchy
