Clutch pedal pulsation
Old 04-01-2012 | 02:33 AM
lilboibounce's Avatar
Default Clutch pedal pulsation
My clutch pedal just act up there is a pulsation now when I press the pedal in. And idk if I need to re-bleed the hydraulic system or replace the clutch master or clutch slave. I need some responds please and thank you. I am going to re-bleed the system tomorrow just in case.
Old 04-01-2012 | 02:40 PM
Billman250's Avatar
Hope you dont need an engine. Pulsing clutch pedal is usually a bad engine thrust bearing. Measure your crank thrust.
Old 04-02-2012 | 05:02 PM
well i just did a flush in the clutch system and now the pedal is soft but i has pressure and the grab point it still the same. also the pulsation is gone. idk if my soft line is going back cause of all the heat in vegas or my master and slave cylinder is going out.
Danwolski
05-23-2018 10:15 PM
kiko2569
11-15-2014 08:09 PM
Kwaalude
08-18-2009 01:34 PM
HonCBRf2
07-29-2008 04:01 AM
rikhemi
04-07-2006 12:52 PM
