Clutch pedal engagement point rising
I bought my '04 s2000 used with 40k mi. It now only have 45k mi. When I bought it the engagement point was high, so I adjusted the clutch by turning the rod behind the pedal.until the engagement point was around a slight press of the gas. That's the perfect position IMHO. Now the engagement point has risen so it's closer to the top.
How do I test how much "meat" I have left on my clutch?
Received 1,403 Likes
There should be an inspection window between the block and the trans. There will be a plate on the bottom side of the transmission where it connects to the engine. You remove the plate and look inside.
