Clutch Pedal Buzz/Rattle
My clutch pedal buzzes. If I put a bit of pressure on the pedal (just enough to put tension on it) the buzz stops. In idle, I can feel significant vibration on the pedal. How do I fix this? Grease?
Thanks,
Jim
Thanks,
Jim
If you can feel significant vibration in the clutch pedal, you have a damaged thrust bearing in the ENGINE.
I have a car here with that issue and the motor needs to come out. I would check the end play in the crankshaft. All you need to do it move the front crank pulley back and forth with a prybar.
Pry it all the way, then all the way out. Post what you see. Go easy, it doesnt take much at all to move it.
05ap2ftw
09-21-2012 07:27 AM
