Clutch not fully engaging
Old 12-15-2014, 04:24 PM
Billman250's Avatar
Received 1,397 Likes on 837 Posts
A clutch cannot be tightened or adjusted.
If you have freeplay, you need a new clutch.
I am not guessing, it is a mechanical certainty.
Old 12-15-2014, 05:48 PM
Belkin623's Avatar
Okay. But you confused me on the free play part. I thought pretty much all manual vehicles have free play at the top and bottom of the pedal range?
Old 12-15-2014, 08:43 PM
Belkin623's Avatar
What's wrong with aftermarket clutch kits in general? And what makes them not last long?
Old 12-15-2014, 08:45 PM
windhund116's Avatar
Received 1,533 Likes on 1,037 Posts
That is one of the advantages of hydraulic operated versus cable or mechanical linkage. No adjustment needed.
Old 12-16-2014, 03:05 AM
Billman250's Avatar
Aftermarket clutch kits rely on friction to hold instead of clamping force, so they slip under high rpm.
The throwout bearings also fall apart in 20k miles, as if on cue.
The pilot bearings seize up prematurely.
They also have horrible clutch buzz.
Its all junk.
Old 12-16-2014, 04:02 AM
iamxpl's Avatar
OEM all the way.
Old 12-16-2014, 09:46 AM
Belkin623's Avatar
Understandable. That just makes me wonder.. What happens when you turbo your S? You just have to go through a crap ton of those aftermarket clutch kits? I read somewhere the OEM clutch can only handle 300 hp.
Old 12-16-2014, 11:07 AM
Billman250's Avatar
ACT pressure plate (modified oem part) for boost, up to 500hp. That and Mugen are the only ones I recommend.
All other parts oem.
Seven11
04-07-2021 10:50 AM
_meh
02-19-2013 11:41 AM
InVTEC
07-26-2011 10:36 AM
lols2000
06-23-2009 04:07 PM
uclanentsu
03-15-2008 11:18 AM
Quick Reply: Clutch not fully engaging
