Clutch Master Cylinder
I have a clutch master cylinder that is slowly leaking fluid into the car. Is this something that can be rebuilt or does it need to be replaced? Would rebuilding with new gaskets be safe?
I was quoted $217 for a replacement.
I ordered a replacement part when I noticed mine leaking but have not installed it. Turns out that some small seep of fluid is normal (I have seen it on several cars) so if that is all there is I expect the replacement will be the same. I just cleaned mine off and check it occasionally.
nEVERCLEAR
06-24-2002 08:11 PM
